KE30/55 LCA's are longer than *E7* LCA's so the sigmas wont add as much camber as when you see them on *E7*'s
Edited by SLO-030
so what lower control arms do i need to add 3 degrees of camber with very little modification?
Edited by Evan G
There is lots of info about this in here and other forums already, you should do a search. But effectively you wont get lots of camber with out doing some decent mods.
