Ke55 4kc Auto can't Do A Burnout?
I used to toast 15's in my 4k ke30. mind you that was with a manual, starting in first and kept them going into 2nd.
Try it on a dirt road where the shoulder cambers off. Put the car parallel to the shoulder. wheels slighty turned towards the road. Apply brakes and throtle. when the wheels get spinning they should dig themselves into the gravel a bit. this and the camber of the road holds the car where it is without the need to fry the rear brakes.
After a bit more spinning the wheels should hit the harder rock, then they should begin to smoke.
Rinse and repeat as required.
I take no responsibility for any fines, impoundment, damage to the slushbox or stone chips from stones flying at warp 9 caused by following the information as descrided above.
