Hi Guys
sorry to ask such a newb question but I am not all the mechanically gifted
One of the lights in me AE92 1990 sedan has gone out and I need to replace I have new bulb but have had some trouble gaining access to do the switch over
I have been told you need to push in and twist but this does not seem to work
any Ideas would be very much appriciated.
cheers
Remove the rubber boot.
Press in the wire spring clip and push across. It should pop out.
Remove globe.
When refitting the new globe, be sure not to touch the glass as the oil from your fingers can damage it once it heats up.
what toyrolla said above :wink:
plus i also remove the headlight housing from the car as well, and if i remember correctly is 2 nuts, a bolt and 2 screws
