July 30, 200917 yr comment_362482 my alternator is charging a bit low under full load, ive read somewere i can swap the insides out with a ford xe 90amp alternator? can anyone confirm this? and pick a part is having a special $15 alternators this weekend win win :D Report
July 30, 200917 yr comment_362486 Most Bosch alternators are very similar internally, Take some measurements and see how you go. You will have to use the same rotor and stator/rectifier out of the bigger unit. I converted mine with what I believe is camry internals just from bits off the shelf at work and it peaks at 100A fully loaded.. Report
July 30, 200917 yr Author comment_362489 geez thats heaps! i want to know what model car i need to get the alternator out of? thanks mate Report
July 30, 200917 yr comment_362494 Only way to know for sure is to have a look and find out if the bits will interchange, I ended up needing a spacer on the pivot mount when I was done because the alternator stator is wider than the factory 45A bit of gear. Report
