Thees pistons are from a 3T engine. Are they anything special or just the standard items?
Also what is this carburetor, I believe it goes onto the 3T as well? And would it be worth putting on in place of the the standard one? My engines only mods are extractors, exhaust and these pistons.
post-2596-1250149980_thumb.jpg post-2596-1250150018_thumb.jpg post-2596-1250150084_thumb.jpg post-2596-1250150132_thumb.jpg
Edited by flamingheads
You tell us what the carb is. Look around the carb base and you will find the model number stamped on it.
Hint... I can sorta see it in the first pic of the carb, but it is a bit fuzzy to make out.
32/36 (I know this one)
DGV 5A or maybe DGV 65A or DGV G5A
EDIT: I just googled it and it's a webber. This leads me to assume that it would give me a significant performance increase. Would that be a correct assumption?
Also any ideas if those pistons are stock or not?
Ok so stock pistons and a webber.
I went to a carbie guy who said the webber'll give me a good power increase over the stock carbie as well as being more tunable and should just need an adapter plate to bolt on.
So questions answered. Thanks guys.
