mmm josh Posted September 8, 2009 Report Share Posted September 8, 2009 hey I've just swapped the head on my old mans 4k, the car idles but if u go anything over 2000rpm or so it dies. Just wondering if anyone knew why?? could it just be the points or something? Quote Link to comment Share on other sites More sharing options...
kiahn Posted September 8, 2009 Report Share Posted September 8, 2009 have you tried checking the basic things like timing, points, dwell and compression?? you might want to try replacing the points and condensor if theyre old just to be safe timing should be around 8 degrees BTDC on 91 octane Quote Link to comment Share on other sites More sharing options...
altezzaclub Posted September 8, 2009 Report Share Posted September 8, 2009 Once you've sorted the electrics like points gap, timing, (and tappets too) then check the carb for leanng out. Let us know what it was if you sort it, it will help others... Quote Link to comment Share on other sites More sharing options...
