Another 4age Site
  • 5 weeks later...
not a bad site, but double check. i spotted a few mistakes :D
  • 4 weeks later...
damn this sites email notification!!!!!!
i can't remember now..... id have to go look again
"There are two RWD 5 speed gearboxes that will fit any 4AGE. These are called the K-50 and T-50. There are also 4 speed versions of the same gearboxes called the K-40 and T-40 fitted to other Toyotas, however these are rare. The 4 and 5 speed gearboxes are externally identical. Apparently the K-40 is only fitted to K series engines."
Is it then right to say that a can fit a 4age into my ke70, using the standard 4 speed??
i thought i had to get a different G/B if i wanted a 4age swap..
if that statement is correct this opens a whole new gameplan..
no.... theres the bellhousings to consider...
and in the case of the "k" boxes, they don't have a seperate bellhousing so you have to get an "A" engine box
and they're from a 3a-u tercel. and you wouldn't bother, K boxes are weak enough behind K engines, you'd lunch one pretty quick behind a 4ag
ahhh i totally understand.. so its like same internals, but different bellhousings?
sweet
yes. except k boxes don't really have "bellhousings" as such, they're one big casting, so the whole housing of the box is different
