Twin Webers Or Turbo
hey all,
just wondering what to do?
I'm buying a 2T-G and i'm going to make it into a 2T/3T-G hybrid,
I've got the option of getting a (plenem ?) and 3T turbo manifold
OR twin webers???
1. If i turbo it, i have to stuff around with efi and all that stuff that
comes with putting a turbo on a car (old car)...
2. If i put webbers on it, i've already got extractors and i will
port & polish head, polish crank, balance most stuff...
I'm thinking more along the line of the webers cos i'm going to be
making my 2door rolla twin turbo, so i'll have the best of both worlds.
just keep that in mind...
thanks, ke30nuts :((
you also have to engineer turbo and efi upgrade (unleaded filler neck, etc) and will have to upgrade front brakes, and you'll lunch stock diffs pretty easy
sidedrafts bolt on and you install a fuel pump and pressure reg and you're away
but there's also a huge power difference. it depends how far you're willing to go, each has its good and bad points
Yeah i beleive taking the old school route with the webers would be easiest and probably not cost you as much as computers, turboes etc. can get pretty expensive but there would be a massive power difference between turbo and NA
yeah I'm not to fussy about the power difference...
power = money
student = not much money
It should still be better than 2T and fill the engine bay a bit better.
mmmm brain wave, what about carby feed turbo?
a cheeper option and no f#*king around with efi, etc
I was thinking along the line of a CT-20 or CT-26
and a weber or something?
comments please :((
on a budget, you'd set it up draw thru, so basically it's just like having a larger engine behind the carby. a bit fiddly to setup but still do-able
