October 22, 200916 yr comment_384487 hey all. Ive got a 4age with twin solex 40PHH Carbs. Ive just got it started and running. It runs but not well. It had no power, wouldnt go over 10-15ks, was back firing out the exhaust and out of the carbs. Ive checked the timing, thats all good and i can think of what else would be causing it. Can anyone shead some light? Cheers josh Report
October 22, 200916 yr comment_384510 Maybe a vacum leak somewhere? Did you change anything else when putting them on? Report
October 23, 200916 yr Author comment_384555 ive made sure there is no air leaks anywhere. And i bought the engine with the conversion already done, they were running/tuned/set up to be on the engine. The only thing that ive changed is it came with a bigport hks manifold with a bigport-smallport adaptor, and ive put a smallport redline manifold on as space was limited. Report
