Hey everyone..
recently i have been having problems with my break system with the pedal been soft and very crap breaking..
I bled the brakes helped a little bit but they have gone soft and when you push the pedal it goes to the floor but if u lift your foot and place on the brakes again they work but not very well..
I replaced the seals in the master cylinder thinking it could be that today have gone to bleed them but the fluid is getting sucked in and pumping straight into the reservoir.. :( what the? whats going on :)
Any help would be greatly appriciated
done a bit of a search on the net but not to sure
thanks -=KE30=-
Josh
ooohh.. probably assembled incorrectly. The first movement of the piston should shut off the hole back into the reservoir, so if fluid is going back up then a seal/piston might be in the wrong order.
thanks mate.. after a quick look at the way the master cylinder was put back together.
piston 2 was put in backwards :)
thank you for your help bled the brakes again and are hard as anything woopie :)
