June 27, 200521 yr comment_53718 hey guys my speedo says i'm doin 50 but aparently (acording to other drivers) i'm only doing 40, it has the original size rims 12's ans tyres (i think) 'sr12 155's' does anyone know why this could be out? and how or where it can be fixed? thanks P.s its a 4 spt manual Report
June 27, 200521 yr comment_53728 I actualy found that the speedo on my KE25 to be the same. Might be something about age, dunno. Mine was accurate with 13's on it. There are places around that will re-cal it for you, but I don't think they're cheap. Put bigger tyres on it. :P Report
June 27, 200521 yr comment_53730 If you have changed diff ratios, that will through it out of calibartion. Possibly the spedo gear inside the gearbox is the wrong gear for your combination. The business below manufactures a product (box with gears - i think) that is placed on the back of your speedo and then the speedo cable plugs directly into that. They can mix and match gears within the box to get the correct ratio that will give a correct speed reading. This is tested by a handheld GPS within the car (from what i understand) Unit costs about $250. Automotive Instrument Repairs 59c Glenvale Cres Mulgrave 3170 VIC Ph. 9561 2366 Fax. 9561 9134 Apparently they also trade as "GM Instruments". Automotive Instrument Repairs Edited June 27, 200521 yr by kangaroosa Report
June 27, 200521 yr comment_53732 Mother of God! He's already bought the car! :P Budget version is buying a $5 bottle of liquid paper and making new marks at important speeds (60, 80, 100). All you need to do is sus out what speed is what, and mark it in white. Don't laugh. There's is many a rally car out there using this system! Report
June 27, 200521 yr comment_53735 i have the same problem with my ute i blew up my original banjo diff and replaced it with a lsd diff out of a jackaroo or some 4wd. the speedo clock shows 110km per hour but really its 100km p/h havent had a speeding ticket since. not a bad thing lol :P good luck with finding the problem Report
