July 9, 200521 yr comment_56542 OK so my car idles below 1grand (usually idles at 1grand) and putts along for like 10 seconds then a burst of normal idleing happens for a split second, then it idles bad again. Idles even worse after accelerating, stopped dead a few times and I ended up having to run with the choke out slightly. Putting along at walking speed when I parked it was doing small bursts of power too. Any suggestions? :n: Report
July 11, 200521 yr comment_57054 check points, same thing was happening to my ke70. yeh the easy fix was run it with the choke out a bit.. cheers Report
