Correct Engine Timing For A 4-ac? Not In Faq!
Yes, thats right, I wanna know what the specs are for the engine timing. I don't see any specs in the FAQ, maybe it should be something that should be added and maybe also add how much advance you cang et out of the car to give it a bit more power?
I'm running at 5 degrees BTDC but i reckon it could perform much better.
Anyone got the specs?
generally anything more than 2 or 3 degrees past stock is a waste on a stock engine
