Wondering if i can run a falcon spring in the front end with my ae86 strut setup?
My mate is running EL Falcons all round, but without the 86 struts.
He has a nice stiff ride all round, my front setup works well for me but back is a bit sloppy.
Also looking to raise it up abit so the cut VL fronts have to be changed, thinking falcons ( which model for 86 struts )
Hear is my current set up
front end
ae86 struts
tokico short stroke shocks
VL springs
vented rotors
braided brake lines
xt-130 lower control arm
t-18 steering knuckles
rear end
cut falcon springs - seem pretty sloppy compaired to my mates.
locked standard diff
short stroke shocks.
bought the car with this setup already in, so not to sure on the model falcon springs or what not.
Cheers, josh
Should be able to if AE86 struts run same diameter spring as KE70! Does your friend with Falcon springs
have aftermarket springs? That could be the reason your front end is a bit sloppier.. Or your shocks are
buggered!
Very cool car! Anything else done to it.. Point us to a project thread? :jamie:
buggered!
my front setup is pretty stiff, the rear is pretty sloppy.
Nah he got the springs from a wrecker out of a EL Falcon so thinking of trying the same and just cutting them to a daily height, will still be low just not as much.
don't have a project thread yet man, trying to get parts sorted out for it still.
Cheers
