Exhaust
hey guys,
wanna build a bit of an exhaust, but don't have access to bender. do u think it wil be ok if i ran the piping from the resonator (half way) straight to the back to the muffler, like without going over the axel? or is that a bad idea?
cheers
what do you mean, run it through the diff? because if you have looked (haven't you?) the diff sits right in the way....
Edited by Jason
alot of rotor boys run the exhaust under the diff, partially because you need a 3" pipe to get decent power out of a bridgey/turbo and there's just not enough room in the diff tunnel to go over
if you don't have access to a bender, get an exhaust shop to make you up a few sections of 90 degree mandrel bent pipe and cut and weld joins at home to suit
you have to put bends in an exhaust, it's just that simple. this is verging on a stupid question
and before you ask, no we don't know what lengths you need, measure and plan it as you go
no like i just wanted everyones opinnion on what they thought about runing the pipe over or under the axel.. it has been done under the axel.. i just want to know whats more ethical?
cheers
well, do you want to scrape your exhaust over speed bumps or not? there's your answer
