I'd assume you'd need a KE55 speedo cable and maybe a KE55 speedo. I'd assume you'd need a early KE30 trimatic tailshaft.
The box should bolt up fine to the engine.
Hmm the tailshaft may become a problem then...
I have a later model KE30 (78) with the updated Grill and Interior pieces.
Ill see if I can confirm if the speedo cable differ in anyway...
Thanks for the heads up JiP
I'm in Brissy northside (Bray Park)
I don't have a KE55 tailshaft no...
I am hoping it will bolt up to the KE30 shaft (the manual tail shafts are the same as each other I am hoping its the same with the auto).
If not I can get a KE55 yoke and get a tailshaft place to put it on the KE30 shaft I guess...
Edited by KaiShin
