February 24, 201016 yr comment_416740 can a 4age 16/20v bolt straight up to the standard 4af gearbox if so how much work is involved? Report
February 25, 201016 yr comment_416877 can a 4age 16/20v bolt straight up to the standard 4af gearbox if so how much work is involved? Yes Modify the dash harness for the 20v, new headers, replace the loom and ecu, and you will either need a fuel tank out of a 4age ae9x or a new fuel pump. someone can tell you what else you will need. Report
February 28, 201016 yr comment_417574 and you will either need a fuel tank out of a 4age ae9x or a new fuel pump. someone can tell you what else you will need. fuel tank out of any any efi ae9x will work not just the 4age powered models Edited February 28, 201016 yr by MYSTIK Report
