A while ago I recall reading somewhere that the front guards on KE70 panel vans are not interchangeable between it's sedan and wagon sisters. Can anyone bring some truth to this?
The reason I ask is, would you be able to do a quad headlight conversation on a flat front panel van?
Cheers :]
Cheers :]
That depends on which flat front you have. Metal or plastic bumpers...
Plastic flat front panel van. However I notice that the front grill is different on plastic flat front wagons.
But either way, the guards on a panel are interchangeable with those on sedans and wagons?
Yup.
If you had the the 'wrong' front, you could use the 'right' guards for quads... Which are the standard KE70 ones. You'd need a bonnet as well though.
Edited by 7shades
you need to change the whole front guards bonnet wiper valance front lower apron
also rad support is different to standard ke70 front,you would need to redrill for quads
