March 8, 201016 yr comment_419829 Hi guys, I need help with my KE10 Speedo Tacho, it seems to have stopped working completely and i need it working again obviously. :D What ways should i go about trying to fix it? its probably the cable at one of the ends? snapped maybe? Let me know any ideas. + maybe i might just update it to a KM speedo + cabling instead of trying to go the MPH again? Is that possible? Thank you in advance. Cheers Simon. Report
March 8, 201016 yr comment_419852 Hi guys, I need help with my KE10 Speedo Tacho, it seems to have stopped working completely and i need it working again obviously. :D What ways should i go about trying to fix it? its probably the cable at one of the ends? snapped maybe? Let me know any ideas. + maybe i might just update it to a KM speedo + cabling instead of trying to go the MPH again? Is that possible? Thank you in advance. Cheers Simon. You can fit in a KE20 km/h speedo (hard to find) and replace the cable for good measure. Report
March 8, 201016 yr Author comment_419868 You can fit in a KE20 km/h speedo (hard to find) and replace the cable for good measure. So youre saying the cable is compatiable with any tacho between the ke10 and ke20? If so i'll just get the cable for now and try and hunt down a ke20 tacho for later use. Thanks phife, much apprecated mate. :D Report
March 8, 201016 yr comment_419919 From memory the KE20 cable will fit the KE10, and if your intrested i have a Km's Instrument cluster for a KE10, just pm me Report
