Everything posted by Rolla_10
Ke10 Gearbox Mount.
Place in Adelaide called Technical Urathanes, I took my busted old crap mounts and he re makes them, both engine and gearbox mounts for about 60 bucks.
4k Running On 2 Cylinders Please Help
As the others guys have said, Check the firing order, 1.3.4.2, and i would do a cooling system pressure test, if you know any mechanics borrow theres, (being in the trade you should know a few), pull the sparkplugs out and check for water/coolent in there, maybe spin the engine by hand to get the pistons to the top to make it easier. if thats all clear and like you said the leads, plugs, rotor and dist. cap and compression are fine, and assuming its not a twin carb, or it has a major air leak on 3 & 4 or some how it swallowed a rag and is stuck in the manifold in runners 3 & 4, then it only leaves 1 thing, and that is swine flu! Basically, Air, Fuel, Compression and Ignition,.
I'm a auto electrian too, please don't bring shame to our trade by asking questions that you should know the answers too, :)
Ke20 Weight
Sedan 2 door (4 door + 20Kg) Auto 715kg Man. 700kg Wagon Auto 745Kg Man. 730Kg
Ke11 Colour
Buy one first, then put on your favorite clothes, get someone to take your pic next to it, then photoshop, you don't want it clashing with your favorite dress.
Rebuilding A 4k
Build the 5k, especially if the car is your daily. less time off the road!
Venitians
O'Brien AutoShades in Black Forest S.A, Dryden Rd, just off South Road near the Cross Rd. overpass, He makes them in creme/biege or black or even unpainted aswell from memory.
What Alternator Is This??
Denso make hundreds of alternators that look similar, go to your local auto electrician and they should be able to cross refrence it with the mesurements and bolt and plug position with their catalogues.
- Rims?
Ke1x Dashpads Remanufacture Discussion
$300 just for a re-skin, i had mine dash/s completly redone, including pins/clips for round that $$$. "Dash Original" in Adelaide.... Takes crash pads in with cricket pitch cracks in them and makes them new, vaccumed down, not that cheap covering crap. They have done 2 ke10's dashes and a ta22 celica dashes for me.
Ke10 Windscreen
I know your not in Adelaide but you might want to ring a Guy called Diamond AutoGlass over here, he put my old windows in and suggested at the time that he could get his hands on new glass for it aswell. Worth a shot cos he could steer you in the right way with a contacts in Vic.
4age Vac Hose Question
The Alternator can make a whining noise if its putting out alot of current, i.e flat battery or low on charge. But also if it hase a diode problem, basiclly if the current is high, 30+ amps don't worry, recharge your battery on a charger over night and the noise should reduce. If the noise is a grumbling sound, then it may have a bearing fault, pull the belt off and spin the pully and have a listen
Speedo Tacho Problem - Ke10.
From memory the KE20 cable will fit the KE10, and if your intrested i have a Km's Instrument cluster for a KE10, just pm me
Early Rolla Cruise January 31st 2010 - Adelaide
You can also have black sheep, your young enough to still have that nursery rhyme sung to you! And also being young and naive you might want to learn to take criticism, even if you think It to be unwarranted. And maybe prove the person wrong one day. But until that day, " 2 teaspoons of cement and toughen the f@$k up!! "
Any rust is, if not we could all cruise around with speed holes. You get it through Regency!
Actually, Rust is defectable, it compromises the body strength of the car....
Just so you know, Henry Ford chose black as its the quickest drying colour and needed to get them off the line as quickly as possible, Yeah it might not be mustard but it sure rhymes with rusted.
Geez rolla68, thats a bit rough, but fair.... not spending too much cash on your rusted/mustard ke20 and claiming to be a stand out car does warrant that type of reply. Having a white ke10 is like owning a red Ferrari, its just the way its meant to be!
Ke20 Project
Mate, you need a girlfriend, or boyfriend...
Pretty good turn out, sorry we had to leave early. thanks Frank & Chobis.
