Timing And Rocker Order
hi guys, i pulled my motor down after the cam broke , i got another cam and started putting it back together , then realized i don't know the timing or the rocker order can anyone help
If you get a manual, you can get a diagram of how to align the crank sprocket and the cam sprocket when you fit the timing chain. Basically there's a dot marked on each pulley, you need them as far apart as you can get them, cam sprocket dot near the top, crank sprocket at the bottom. Then you fit the chain, i THINK there is an even number of links either side of the dots.,
That will get you in time crank-camshaft.
at the bottom of the page and to the left are the timing marks for a 4k.
Factory.pdf
thanks mate , now does any one know how too set rockers and the method u do it in , i know the gaps but i am unsure on the process
