what springs fit the front with standard struts and what can i put in the back i only want it a little bit stiffer not much and i could put my weld on coilover kit on the front if nothing really suits but id rather keep it for another car
Edited by mitch-12
from what ive heard falcon springs fit all round.. and ra60 or ae86 struts. not 100% on that though.
also from what ive read, in the rear you can use vn-vr commy rear shocks in a ksev and also suzuki sierra shocks if you want to lower it, but apparently these are very short and your likely to get defected with them.
in mine i have TJ magna and VE commy springs. not sure if they are fronts or rears just had them laying around the workshop. cut off about 2-3 coils off each set and the car is the stock height o.O but i wouldnt suggest using these springs as even at the stock ride height the springs are held captive by zipties. i mean, sure i have a stiff as f@$k ride (compared to stock) but I'm just waiting for the day i snap all the zipties and drop a corner. when the load is applied to the springs they only compress like 1mm. they are made for a 2-3tonne car and I'm using them in a bog stock ke70 lol.
Edited by Dropz
thanks mate um wats an ra60?
the vn-vr shocks would be alot stiffer as theyre made for a much larger car which not only has alot more power, but is also built to carry around alot of cargo (wagon, duh :D lols) so i would think that it would be worthwhile getting some. if you want to lower it maybe get some short strokes for a vn wagz.
