May 10, 201016 yr comment_436119 hey all my radiator is shagged and i need to replace it but don't have the money atm but my sister has her old holden astra hatch which is also the same style as the toyota corolla hatch. the radiator on that is near perfect but is bigger and wider that my rolla one. If i get the radiator to fit in there will i have any dramas if its too big? or will it just work like normal? Report
May 10, 201016 yr comment_436124 hey all my radiator is shagged and i need to replace it but don't have the money atm but my sister has her old holden astra hatch which is also the same style as the toyota corolla hatch. the radiator on that is near perfect but is bigger and wider that my rolla one. If i get the radiator to fit in there will i have any dramas if its too big? or will it just work like normal? It should be fine as its the thermostat that sets the temp the motor will run at. It just may open and close the thermostat a bit more, nothing to worry about usually. Report
