thimio38 Posted May 17, 2010 Report Share Posted May 17, 2010 hey guys this topic has probably been brought up before but i couldnt find it. I'm just wondering if ajps coilovers are an easy fit to a ke30 and if not whats a fair easy suspension upgrade? also I'm clueless about a easy brake upgrade. something that will pass engineering in victoria. Quote Link to comment Share on other sites More sharing options...
RedKE30 Posted May 17, 2010 Report Share Posted May 17, 2010 Yes A J P S can make you a set of coil overs to suit a KE30. Brake upgrade depends on how serious you want to get. Search around for the Corona/Puegot/Hilux upgrade. I think there's an RA60 upgrade aswell. Quote Link to comment Share on other sites More sharing options...
towe001 Posted May 19, 2010 Report Share Posted May 19, 2010 I wouldn't say its a huge upgrade but T-18 struts. On the brake rotors your going from a 218mm solid rotor up to a 230mm solid rotor, not much but the biggest thing about it is the shock absorbers, they run a bigger diameter tube which gives you a huge range of absorbers to pick from - commodore, corona, cressida, camira just to name a few... Quote Link to comment Share on other sites More sharing options...
