I am putting disc on my 69 corolla i have a article by Alex Bates but the caliper mount/backing plates have a four bolt mounting i got them off a 73 corolla but they don't line up with the ke10 struts do i have to modifiy the bracket from the article it say it a direct fit can any one help Thanks Nardy
in australia, you'd have to get such a changeover certified by an automotive engineer, so you'd ask your engineer. do you have such a requirement in america?
if not, i'd weld up and re-drill the backing plate to suit the strut, or just make a whole new caliper backing plate from the same thickness of steel as the original one. alloy if you're feeling like spending money
don't weld and drill the cast strut
ke30 and te30 have different front struts and different sized brake rotors, no idea about the calipers and backing plates and rotor bolt pcd
it appears there exist ke1x struts with a different backing plate bolt pattern, which is what nardy has
no, america just has emissions standards, especially in california, wher they can sieze your car if it has been modified
my old struts had a flat plate with 4 bolts holding it on and two wheel cyls
maybe felix or rol-110 can post pics?
my old struts are in san diego
"k" model corollas are pretty rare out here; most were 2tc's
