So I am doing a manual swap into my Ae82 4ALC, I pulled a transmission from an 87 FX16 GTS. I read somewhere they came with a c52, however mine doesnt appear to be a C52 from the pictures I have seen. It only has one "Ear" but looks almost identical to the c52 otherwise. Basically I need to know which CV axles to buy.. Does anyone have an idea of which transmission I may have, or what axles I need?
I pulled numbers off the trans case: 61106943
And off the plate on the trans: 1NXAE89G0, followed by 1Z412164
Does anyone know how to decode this business? Thanks for any help in advance.
Did you happen to see what the VIN plate on the FX16 said?
In general, a FWD Corolla gearbox from that era that isn't a C52 will be a C50, which would be what the stock manual gearbox would be for a 4AC anyway.
Somewhere like (AE82 Owners Club would be a better place to ask, Rollaclub is fairly heavily biased towards the older RWD Corollas (not saying that you're not welcome, just that the majority of the knowledgebase is for the older variants)
I scrapped the Donor car and didnt think of getting the Vin. I think I found some axles for it. I hope they work!
Thanks for the help sir.
