Ae82 Help
hey guys just recently noticed that my ae82 sedan reverse light dosent work ive checked all fuses and replaced the bulbs still nothing why? And how can i fix this please
Thanks
Izak.
Manual or auto, Possible the reverse switch is faulty, I can have a look at it if you need.
  • 2 years later...
I got the same problem in my ae82 hatch fuses good bulbs good but I can't check the switch let alone wouldnt know how lol... is any1 near burwood that could help or could offer advice?
Your reverse switch is located on the gearbox, see picture below, circled in red. To test, disconnect the switch then bridge the two terminals on the wiring loom plug. Switch on the ignition & check the reverse lights, if they work the switch is stuffed, if they don't the problem lies elsewhere.
Edit: I'm presuming manual gearbox here...
Edited by carbonboy
Changed my switch now reverse lights work fine :) worst part is getting past the aircon structure bloody pain... but its done now and I'm cheering... :) I envy those of u who have air con...
