Carb Setup Issues
on my 5k 32/36 weber setup i have got two tiny hoses and 1 wire that 1 don't know where to hook upto... 1 is from the dizy and 1 from the intake manifold. the wire goes to the loom and used to be to the old carb.
do these need to be hooked up or blocked off?????
also the fuel line to carb has an inlet and outlet... does 1 of these need to be blocked off and jus run the fuel line in or??????
OR has anyone got some pics of there weber setup on k series.....
cheers
zane
Fuel line - yeah just block one off.
2x tiny hoses are vacuum lines. One at least needs to go from the bottom of the carb to the dizzy for vac advance.
Wire to the carb is for the stock fuel cutoff solenoid. Does you weber have an electrical plug on it anywhere?
