July 17, 201016 yr comment_452374 does anyone know what accelerator cable to use when you put a webber on a 5k in a ke30? seems to me the standard one is a bit short.... cheers Report
July 17, 201016 yr comment_452395 G`day mate, when I put the weber on my 4k in my ke70, I was able to use the standard cable. If you are mounting the carb with the fuel inlets at the front, you should only have to make a cable adaptor that mounts on top of the tappett cover where the standard cable holder clip is now. If the ke30 cable is actually too short, maybe a ke70 will do the trick. Good luck and cheers. Report
July 19, 201016 yr comment_452799 Yeah as oldfella said just make a new bracket to hold the cable in a closer spot. :laff: Report
