SLW42 Posted July 25, 2010 Report Posted July 25, 2010 if you want mad camber go for silvia lca's aswell (also good for a brake upgrade too :yes: ) Either that or rose joint a set of sigma or xt130 lower control arms :yes: Quote
ke70dave Posted July 25, 2010 Report Posted July 25, 2010 how about a pair of camber tops? he wants to adjust the camber, not just make it more negative longer LCAs wont help you adjust, it will just make more negative on both sides (unless you rosejoint like slw42 suggests, but thats a little extreme!) only problem you may find with camber tops and standard suspension is that the spring is quite large inside the suspension tower so you may not get that much adjustment. but i think youll get some. Quote
