August 3, 201016 yr comment_456729 In SA it's 335mm front and 320mm rear. I can back this up as the correct minimum eyebrow height. :( Report
August 3, 201016 yr comment_456756 last time i checked it was 325mm fr and 300 r. bastards have changed it Report
August 4, 201016 yr comment_456769 weird if you were to still ring regency they say eyebrow hieghts. I reckon the average Mr Plod on the side of the road would go by eyebrow heights too. Then again if you pull out the book etc and show him he will just end up sending you to Regency for being a smartass :( They don't like it when you know your stuff and quote it. I have been done for being prepared before :ninja: greenmac80, when's the last time you spoke to Regency about that? Because those guys work for the same people that wrote the bulletin on ride height, it'd be typical of the DTEI to not know the rules they've set. BUT having said that, they have published an info page on the eyebrow heights on the same page, get Regency to fill out those details and keep a copy in your car anyway. Not only that, but eyebrow heights don't always correspond to anything to do with ground clearance. You could have the eyebrow's correct but your zorst could be hanging low. Report
August 4, 201016 yr comment_456841 greenmac80, when's the last time you spoke to Regency about that? Because those guys work for the same people that wrote the bulletin on ride height, it'd be typical of the DTEI to not know the rules they've set. BUT having said that, they have published an info page on the eyebrow heights on the same page, get Regency to fill out those details and keep a copy in your car anyway. Not only that, but eyebrow heights don't always correspond to anything to do with ground clearance. You could have the eyebrow's correct but your zorst could be hanging low. march this year perhaps april was the last time i rang them about it. Report
