Everything posted by ke30 driver
Ke55 Sr20 Brake Master Issue
An early ke30 master is smaller but you'll need the early ke30 booster aswelll
Brake Fluid Leak
Unless u spilt brake fluid. It shouldn't be leaking. Rear seal in master cylinder gone. Either recon or replace master cylinder
5 Speed Speedo Cable
did u convert from auto? If so u need manual cable and speedo drive
What Is It Worth?
put it up for 4000 and try ur luck
4K (Ke70) Alternator On 3K (Ke20)
may have to change mounting brackets and have to change wiring.
Spotted
yeah that thing is awesome!
Upi Spotted
not much at elizabeth yard there is a complete green 20 bumpers lights and grill look good. Theres a rt40 and a mr2 with 4age in there but cams are gone.
Joshs Ke36 Panelvan Project.
good choice on colour guys really suits it. can't wait to see it finished.
Cruise 10Th July !!
i might come along to this one will be my last chance in the corolla :(
Cruise 10Th July !!
Does Anyone Rebuild Diffs ??
once you do one they arent that bad. Just use the right tools and a manual and just take ur time
The Crown
ford focus and mondeo and some volvos are 108
Slo-038 + 10Psi
where did u buy the jets from? Why r u going back to points?
Throttle Cable For Dell'Orto Sidedraught??
have to custom make linkages. Or take the throttle wheel off standard carby
Adelaide Wreckers That Have Ke30'S
I'm wreckin a manual ke55 in the adelaide hills. Ring or txt 0448495319
Oil Cap & Oil Issues .Help. : ?
3k is push in type. 4k and later are screw in. Find ur self a 4k rocker cover
Un-Level Ride Height?
only way to fix it is to buy new leaf springs. i had the same problem, i put 2nd hand set in and had the same problem. got new springs and fixed it
1980 Ke55
new rims. now just need to get busy painting and polishing. still have to decide what colour centres to go with
Anyone Bought Off This Company Before?
yes i have bought some previously and had no troubles
Spotted
seen ra28gt on port wakefield road, didnt look like a 20 from a distance with quadlights
1980 Ke55
done a bit of work to this lately. getting extractors and 2'' system put on next week. got a sidedraught weber on it too(what jets do people normally run a a single 42dcoe?) need to get my aircon running for summer too! otherwise just been cruisin around. new pics will be soon
Spotted
seen a ke55 parked down the gorge almost the same as mine yellow lowered on black stockies
Ke55 Electical Bug
thats what i was thinking of doing. what is the issue with the cluster is it repairable?
Ke55 Electical Bug
hey all, got an issue with my fuel and temp gauge dropping out when i have my high beams on and heaters on full. anyone had an issue like this? i havent had time to look at anything so i need some pointers cheers
My Ke26 Panovan
seen this thing at elizabeth is pretty damn clean pity bout lh gaurd tho
