Brake Fluid Leak
The other day, I replaced the front brake hoses and bled the brakes. When I was finished, I had a bad fluid leak from the bolt at the back of the servo. It leaked when the pedal was pressed. I've tightened the bolt and I think the leak is fixed. Should there be any fluid there anyway or is this a sign of a bigger problem?
Thanks
Edited by peterd
Unless u spilt brake fluid. It shouldn't be leaking. Rear seal in master cylinder gone. Either recon or replace master cylinder
Thanks. I can see how it works now. Hopefully the recon parts are still available.
