3k Trouble
hi, my 3k is missing in cylinder 3 and i can't find any sign of why...
i did a compression test and all cylinders are around 150psi
i took the head off and had a look but i don't have a tool to remove the valves, does full compression rule out a valve problem?
the dizzy cap is near new and points are clean,
i swapped the leads and sparkplugs around but still cylinder 3 misfires
head gasket looked fine,
no signs of anything wrong but still running on 3 cyl!!
any ideas anyone???
guessing its a valve problem as its the only thing i couldnt look at properly...
could be a bent push rod or valve clearances not set properly
Is the plug wet ?
What happens if you crank over with plug out, and have plug sitting on rocker cover with HT connected can you see spark ?
