August 11, 201016 yr comment_458496 hi, my 3k is missing in cylinder 3 and i can't find any sign of why... i did a compression test and all cylinders are around 150psi i took the head off and had a look but i don't have a tool to remove the valves, does full compression rule out a valve problem? the dizzy cap is near new and points are clean, i swapped the leads and sparkplugs around but still cylinder 3 misfires head gasket looked fine, no signs of anything wrong but still running on 3 cyl!! any ideas anyone??? guessing its a valve problem as its the only thing i couldnt look at properly... Report
August 11, 201016 yr comment_458656 could be a bent push rod or valve clearances not set properly Report
August 12, 201016 yr comment_458746 Is the plug wet ? What happens if you crank over with plug out, and have plug sitting on rocker cover with HT connected can you see spark ? Report
