September 22, 201016 yr comment_470778 I'm running a TA22 with a stock rear diff, LSD in the future and was just wondering has anyone converted these to disk rear and what did they do and use to do so, any help would be great cheers Report
September 22, 201016 yr comment_470782 Have done it using st141 rear disc ,from a live axle .Not sure about the irs rear ends .Need to use longer bolts for the axles and the axle retainers off the corona axles (don't forget these)pretty much bolt up converstion.Or and hand brake cables as well (corona) rob Report
September 22, 201016 yr comment_470993 Normally need a spacer ring for each axle for the disc brake conversion mentioned above. There is a very good "how to" thread on toymods that covers it. Report
September 23, 201016 yr comment_470999 ive heard of people using r31 discs on t series diffs, ill prob do the same thing but ofcourse needs a bit of work to fit. Report
