September 24, 201016 yr comment_471354 I'm still trying to source a diff and rear brake upgrade for my 20. Will KE70 axles, brakes and centre fit into a ke20 housing? Report
September 25, 201016 yr comment_471471 i got a fiat diff setup in mine. disc brakes and an added brake booster. stops great and the diff handles the punishment i give all day long. its a strong setup. and light and small. i recommend either fiat or bmw diff. pics below. Report
September 25, 201016 yr comment_471487 I'm still trying to source a diff and rear brake upgrade for my 20. Will KE70 axles, brakes and centre fit into a ke20 housing? no, ke70 axles are too long, centres different etc. brakes can be modded to fit, but if your going to that trouble you may aswell upgrade to a stronger diff at the same time. i don't know of any strong diffs that are the right length to bolt in. most people usually go borg warner 78, F series or G series toyota. another option to look at would be nissan h190 Report
September 25, 201016 yr comment_471489 i recommend either fiat or bmw diff. pics below. that sounds like a good conversion you have made. how much power do those fiat diffs handle, and whats the availability of different gears, lsds etc? did you have to shorten the diff to fit it in the ke2x? oh which bmw diff do you speak of? everything i can think of since the 60's has had irs, and been fairly weak. Report
September 25, 201016 yr comment_471494 contact a fellow member named Curly.he would help you. he is located in Brizzy if i`m right? Edited September 25, 201016 yr by drc_ke20 Report
