Performance Wheels Closing Down
yeah i used to use formula ford fronts on my KE25. rears are 14" iirc. wasnt too bad on my car, because it was slow, and not a whole heap heavier than a FF. i wouldnt use them on something heavier like a sev though.
Rip Daves Old Car.
he just bought a roughish AE86 off a bloke on performance forums cheap, and is now trying to resell it with all the drivetrain gear (not even installed) on facebook. thank god his giving up, so hopefully the ae86 doesnt end up like the sev!
Reason I Left Rollaclub
theres one at centre rd wreckers in melbourne atm. when i was there a few weeks back it had a really good interior and stuff. only bits missing were pretty much the front hubs.
Vic Wreckers
i was there about 3-4 weeks ago and there were no ae9x's that i remember. but as you would know a lot can happen in a month at the wreckers :)
Buying My First Mig Welder, What To Look For?
i disagree. you can learn quite a lot from buying a welder and just laying beads. will give you at least a slight idea about what your doing, so the poor tafe teacher wont have to completely baby you. but i agree on the tafe course bit, absolutely essential if you want welds that have any chance of passing engineer's requirements. its a bit late now, but late last year i bought a cigweld weldskill 250a single phase MIG. its a cracker of a welder for the home hobbyist. uses 15kg spools, euro torch plug, can do aluminium, has all the basic adjustments, and came in under $1k. only thing its missing is the 'inverter', but mine will never leave the shed, so i don't need it :)
3K Connversion
install it on the exhaust. make a valve on the exhaust controlled by a solenoid so when you back off the valve blocks the exhaust off.
Who Can Weld A Diff Centre?
Mate welding diffs is piss easy if you know how to weld. Drop the crownwheel & carrier assembly out and give it to a boilermaker. Any engineering shop should be able to do it. Just give it to them complete and tell them it has to go back the same way it came apart, with no slag/splatter in the axle splines or the mating faces. once its done pull it apart again and religiulously clean everything and double check for splatter. If thats all good reassemble and fill with oil. then robert will be your mums sibling.
Upcoming Events
bcc Twilight khana/motorkhana at bagshot is on saturday week iirc
Ae82 4Ac - What Activates The Charcoal Canister Purge Valve?
Nah mate its long gone. Thanks for having a look. Much appreciated
Hey guys, nearly ready to get my AE82 on the road but ive got a problem with the fuel tank getting pressurised and pushing fuel past the fuel pump (car is on duel fuel) and hence running like shit. Ive had the tank out and made sure all the lines are clear. The charcoal canister isnt blocked etc. Basically ive traced it back to the purge valve. Now the purge valve does work, but I'm wondering if anyone knows what tells it to turn on and off? I'm thinking one of the vacuum solenoids, but I'm not sure which one. So if someone knows it would be much appreciated. I can then much around with vacuum ports to modify the way it works. Oh btw ive tried leaving disconnecting it so the purge valve stays open all the time but the car runs rough and stalls so i don't really consider it a viable solution. Thanks guys, cameron.
Upcoming Events
as jimmy said, its a fair bit longer than a regular autocross. think more like a rallysprint. normal autocross' don't require cage. and atm BCC doesnt require helmets for motorkhanas.
Upcoming Events
just a reminder, the BCC long course autocross is this sunday. I'm entered, in a galant unfortunately (the corolla doesnt have a cage). forcast: WET :)
1971 Ke25 Coil Ballast Resistor Wiring
- 1971 Ke25 Coil Ballast Resistor Wiring
sorry dude, just went out to take a photo for you but my phone batteries too flat to take the photo. will have a pic for ya by 7pmish tomorrow if someone doesnt beat me to it.- Bagshot Khanacross July
pfffft. minor issues. the bcc lost my cams lincence in march, and still havent found it. ill be fuxed if I'm paying for it twice. the membership sec has put an astrix next to my name so i can't race again until ive sorted it. - 1971 Ke25 Coil Ballast Resistor Wiring
