Booster/Master Cylinder Upgrade?
What the easiest booster upgrade for a ke20? I'll be using ke70 front discs and ke55 rear drums and i'm not sure the standard master cylinder will do the job.
Any ideas or know how?
  • 2 months later...
hey man new comer here. yeh great topic can anybody please giveus some information?
Have a look at KETURBO25's ride. the Bloke that built it cut a part of a KE3x peddle box out, mounted it in the engine bay, made up a longer pushrod and mounted a PBR booster and master cyl.
double post
Edited by styler
looked a fair bit into this a while ago, found...
the old galant ones literally bolt up and provide twin circuit in GC, GD models
in 17.46, 19.05, 20.64mm
its possible the 19.05 circuit may need modifying from drum/drum to disc/drum setup
regarding the residual brake valve in the front which is for drum only and can be removed
to convert it to a disc circuit but check with a brake shop first to make sure this is
appropriate.
check this out:
ATAP catalogue
find the bookmarks up top to navigate
Edited by styler
