October 6, 201015 yr comment_473801 This is true. However in an AE86, the engine loom is only one of three body looms that run the engine (ignoring the power feed to the fuel pump). In a rear wheel drive factory set up, the charge/headlight loom & underdash loom also contain wiring feeds back to the ECU - VSV's and idle up circuitry, speed sensor, fuel circuit relay and injector power etc. The fuel circuit and injector power can be wired in easily enough, but I have seen a lot of really bad jobs I am amazed haven't ended up in a ball of fire. The car I did was an ADM sprinter, I ran a separate fuel power and just did the changes in the dash forward which included adding power wires to the non efi dash loom and to the front body harness. The 82 also required the 3 looms as shown in my link above. Report
