October 29, 201015 yr comment_478884 hi new here ,got a 73 ke20 sedan want put mazda series 4 rx7 4 spot calipers on poss going to use ke30-55 struts any ideas on calipers mounts, not shore on discs poss rx7 also any pictures out there have done lot searching also want keep wheel trap same as orig if can i,m putting ca18det into going to be full engineered poss with 15 inc tyres . Report
October 29, 201015 yr comment_478885 what is "poss"? and what is "wheel trap"? what makes you want to put the rx7 jobbies on? Report
October 29, 201015 yr Author comment_478892 what is "poss"? and what is "wheel trap"? what makes you want to put the rx7 jobbies on? sorry about that spelling,poss means it will be engineered in nsw so i thing 15 inch wheel will be max size and i,ve got set rx7 calipers and they seem to be nice light weight 4 spots, and ke30 and ke55 struts ,and wheel trap shouldve been want keep front wheel track same as the orig if can. Report
October 29, 201015 yr comment_478981 ...... http://www.rollaclub.com/board/topic/11306-brake-upgrade-for-ke20/ http://www.rollaclub.com/board/topic/1704-bad-spelling-in-posts/ :wink: Report
October 29, 201015 yr Author comment_479001 ...... http://www.rollaclub.com/board/topic/11306-brake-upgrade-for-ke20/ http://www.rollaclub.com/board/topic/1704-bad-spelling-in-posts/ :wink: thanks for the help out . Report
