November 22, 201016 yr comment_483643 hey guys, my ke55 tail lights are not working and from what i can see there is no reason why... fuses good, bulbs good and all the connections look clean. that is all i know what to look out for. what else could it be? cheers for any suggestions lads. dave :) Report
November 22, 201016 yr comment_483645 Do you have power going to the back of the light? Do you have continuity between the earth of the light and the body? If the globes have been replaced are they double filament or single? Do the rest of the parks work? Do the brake lights work? Ummmm..... Report
November 22, 201016 yr Author comment_483672 Do you have power going to the back of the light? Do you have continuity between the earth of the light and the body? If the globes have been replaced are they double filament or single? Do the rest of the parks work? Do the brake lights work? Ummmm..... ok thanks heaps for that... double filament globe are there i know, brake lights are fine, and what do you means by parks sorry? i will check it all out asap and come back with some results i hope. cheers Edited November 22, 201016 yr by dave_89 Report
November 22, 201016 yr Author comment_483721 yea front park lights don't work for whatever reason.. Report
November 22, 201016 yr Author comment_483726 Do the dash lights work? funny that. i was just about to ask, they are also cooked but i never really bothered really Report
November 22, 201016 yr Author comment_483743 ok lovely. i know the fuse is good (checked it multiple times) as for the relay, where is it located? and would a known working stalk fix the switch problem? thanks heaps Report
November 22, 201016 yr comment_483747 You can just unplug it and try, the relay (if even fitted) is underneath that kick panel next to the accelerator pedal. If you have a multi meter check power going into the switch, according to the diagram it could be a white wire or a grey wire or a red/green....this is easier in person. Report
