Suspension And Brake Upgrade Ae71/Ke70
Hi all, i have been looking at doing 4 wheel disc brake conversion on my ae71.
I was thinking of using rt132 corona front end basically unbolting the LCA (lower controll arm) and the top of the strut form the tower and slotting it in the ae71 for the fronts, and using a rt142 corona diff with disc brake for the rear.
I know i have to get the mounts on the diff modded, is there anything i have to do to the front end? such as strut camber tops and master cylinder?
Also the rt142 diff is slightly wider 1420cm i think, but i don't think this will matter as I'm using the corona 14's, so using the rt132 LCA would that make the track up front wider?
If it does, it wouldn't look so noticable
I assume i can get slotted rotors from RDA for both front and rear but my main concern is, would this set up be sufficient for a 20v conversion, power compared to braking ability?
i have been thinking about the pro's & con's for a while and can't make my mind up?
Also what shocks are available for the rt132 corona's as i want to lower it, but don't want it too stiff as i won't be sliding it! believe it or not...
So I do this or buy a set of BC coilovers for a AE86 then go with slotted vented rotors with series 4/5 rx7 4 pot callipers with the aid of AJPS mountings...
I DO have a lower budget though
thanks for the help sorry its so long :blinks:
