December 9, 201015 yr comment_487302 Hello every one..... i am a new member and u guys can see my ride in the members gallery area. previously this ride was being used by my elders but now its in my custody and wants to replace the engine as the stock engine is wearing out and is now consuming engine oil (1 liter to 2500 KM's) please advice me about the engine, keeping in mind that the car is totally in the stock condition, stock gear box (4 forward), stock differential and stock seats and body parts.... please also keep in mind that i am living in pakistan so i can buy an old motor (slightly used) easily rather then a new motor... please also advise me about the differentials, brakes and gear box... Report
December 9, 201015 yr comment_487303 its got a 3k in it now? if you want some improvement in power put a 4k in. if you want a POWER HOUSE put a 5k in it. everything bolts on/ interchangable Report
December 28, 201015 yr Author comment_491002 @even G yeps its running on stock 3k engine... lets suppose if i put a 5k in it, i have some querries.... gear box is stock i.e four forward... brakes are also stock and rear differential is also stock so if i swap the engine will it create a problem in handling or will it go ???? Report
December 28, 201015 yr comment_491004 you wont be blowing diffs etc etc. its gets up and moving a 5k weighs prob 10kg more? Report
January 1, 201115 yr Author comment_491990 @even G i checked for 4 k and 5 k used motors but prices were too high... and fuel prices increased as well :( around 2 aussie $ / liter :( so i decided to over haul the original engine.... i will be posting and sharing pictures as well.... can i do any thing to make the original engine having more power???? Report
January 10, 201115 yr comment_494294 aye ive got a 3k sittin under the house nothin wrong wth it just need rockers and pushrods it didnt blow smoke or anything ran great r u intersted Report
January 10, 201115 yr comment_494298 stick a nice sized cam in it. play with the cylinder head and get everything balanced Report
January 17, 201115 yr Author comment_496110 @even G i have overhauled the stock engine and the pictures are in my gallery area. i was planning to install lsd in it but i am not sure that weather it is a good idea or not ??? engine responce is quite good and after changing the drive shaft cross member my car is quite smooth & quite.... i have installed a CNG kit as well :) its quite cheaper to run on CNG....but the engine pick up gets too slow.... ..... one of my friends while driving my car hit the right front fender .... and rear view mirror was broken... i managed to find a used one for PKR 4500/- i.e 90 aussie dollars.... but the mark (toyota logo) of the right fender was also missing and regardless all of my tries i am unable to find one.... i will try to find one else i will try to cast a logo my self keeping in mind the orginol logo.... lets c what happens.... ....... now in the next step i am planning to upgrade the seats.... original seats are not comfortable now ...how ever the orginal black covers are still there ???? what do u guys suggest???? should i replace the seats or try to get some foam and make the seats better keeping the original cover and looks ???? Report
July 17, 201115 yr comment_540207 Throw a 3tc in, cheap as chips and shot on any k motor. Also I have custom engine mounts to bolt one straight into a ke20 if you're interested Report
August 2, 201115 yr comment_544118 A 5k is the easiest and cheapest bang for buck. I went 2tgeu never again... Massive headache, it goes now though Report
