December 21, 201015 yr comment_489790 this may have been covered before but search didn't bring up the info i wanted i have a KE35/55 hardtop corolla and am looking at running a fully worked sr20det in it and wondering what diff and brake setups people have run any help on setup's are greatly apprciated thanks guys Report
December 21, 201015 yr comment_489806 i have hilux 4 pistons calipers up front, hilux diff 3.7 lsd up the back with ford xd solid rotors unsure of the booster i have can't remember have to have vented / solid combo to be engineered with the SR Report
December 22, 201015 yr comment_489846 Hello. Hilux are the go but look for something a little smaller than the E series if you can. F series are the go unless you are making stupid power. Then you can use LSD centres from Lexus Altezza, MA61, Crown etc. The RN47 2wd lux has a pretty tought little E series if you decide to go that way. The good thing about a Lux diff is it is already a leaf diff so will need minimal mods to be fitted, as long as you go for an earlier series of lux the width could be either similar or the same from the get go. I think RN25 lux has the right width of diff too. Report
December 22, 201015 yr Author comment_489958 thanks for that guys also where can i buy coilovers for the front of it Report
December 22, 201015 yr comment_490005 Coilovers, best cheapest option would be the HSD sleeve kit from these guys: http://otomoto.com.au/HDSystems/sleevekits.htm Report
December 27, 201015 yr comment_490841 I'm also on the build with a 55, anyone used the torago diff's before? Report
