Not entirely true. It depends on the 5k. If you have one with the deep dish pistons then you'll actually decompress it and it should be good for turbo charging. If you have the shallow dish then you'll probably end up with a pretty high ratio, but I don't think it will be ridiculous. The best way to find out is to measure it if you can.
Thats a better answer :yes:
What is it, about 9 out of 10 (if its australia) you'll have the 5k with the dished pistons so you'll wind up with a loss of compression. Still be an idea to pull the head and find out. Have a search its been covered with a few photos of the pistons from memory.
