brendan
Everything posted by brendan
  1. Does anybody know where this ke30 got to?
  2. Hi has anyone tried the fajs twin dcoe carbs They look like webber copys Do know if I should buy genuine webbers or or go for the cheaper version
  3. Wiring is all good Ill check that mag and hall setting Its just the pick up on the dizzy wont send a signal to the msd
  4. I have a 5k with elec dizzy put a msd 6al in and can't get it to trigger Any ideas whats going on here? Cheers
  5. Can anyone recomend someone in sydney to enlarge the valves
  6. Hi guys Putting a msd on my 5k Will it be ok to run the 5k dizzy Has anyone done this bedfore?
  7. Hi I know nothing about celicas but I thought all ta22s came out with twin cam 1600s I'm looking at buying one but it has a single Cam single carby 1600 Which model cam out with the twin cam?
  8. 1984 ke70 Worked 5k twin webbers gilmer and 5 speed Chrome steelies
  9. brendan posted a topic in General Mechanical
    Hi guys Putting a 12a or 13b in my 70 within the next couple of months does anyone have any pics of front engine mount and gearbox mount Thanks Also when I pull the 5k out it will be going of sale keep you guys posted
  10. hi guys yes its the standard grill just took out the chrome vents and welded it up just have to finish wireing it up and put interior in then get rego'd then it will be ready to have some fun
  11. My 25 nearly finished
  12. Ho Does anyone make a crossmember to bolt sr20det into ke70 Cheers
  13. I'm talking about the jets
  14. Hey guys I have twin carbs of a ke15 sprinter on my 5k and I had the two carbs rebuilt . Started it last week and runs fine but noticed while idleing it drips out of the back carb but not the front one .ive played with the mixture screw to try and get the front one to leak the same but can't!(the jets) Is that normal? I'm running a vortex electic fuel pump which is rated at 4-6 psi Any help would be great cheers
  15. I have no tailshaft and need 1 but not sure Which one I need .ke30 k50 with a 20 diff So what tailshaft do I need out of what model?
  16. hey guys are you sure I can use the 25 tailshaft Because I tried it and the 25 yoke is to small
  17. Hey guys Recently put a 30 5 speed in my 25 What tailshaft do I fit ?
  18. Hi guys will a .ke70 5 speed clutch fork work on a .ke30 5 speed as I can't find my 30 clutch fork Cheers
  19. Hi guys Bought a/c for my 70 yesterday and installed it but There's a couple questions I need answered 1.Does the ke70 wiring harness have the wiring there To plug into the a/c box ,or do I have to get an auto elec to wire it up? 2. I'm missing the condenser , can I use something out of Another car ,will an ae82 condsor fit up to the ke70 fittings?
