December 25, 201015 yr comment_490510 Ok hope someone can help me here no search results. I have a ke30 2 door and want to upgrade to turbo efi. I also can have a 4efte low ks engine loom ecu etc for a few cartons of piss. Good little motors I've heard, but need to know wich box to use, or can I make adaptor plate for me box? Any info is GREAT. cheers. Report
December 25, 201015 yr comment_490515 Hey man, have a look at this, don't know if it has gearbox info but looks tuff http://www.performanceforums.com/forums/showthread.php?t=67216626 "The engine is bolted to a 10mm steel adapter plate which is in turn bolted to a T50 previously behind a 2T, which has had 10mm machined off the bellhousing. Also he had to make a piece to fit spigot, but I never saw that so no idea what he did sorry. Uses stock Starlet flywheel and clutch and the starter is bolted to the adapter plate." Edited December 25, 201015 yr by jono1986 Report
December 25, 201015 yr comment_490522 Luc - Greenmac on this foums is doing this conversion right now with an adapter plate. Report
December 25, 201015 yr Author comment_490530 Luc - Greenmac on this foums is doing this conversion right now with an adapter plate. Great I'll check it out. Thinking due to light weight, good after market support and decent power potential this is an ideal option for a ke. Report
