December 28, 201015 yr comment_491021 hey guys, i have a ke70 with a blacktop 20v and a t50 behind it the speedo does not work i have swapped the speedo cable and the speedo itself. and it still does not register speed, I'm guessing the shaft the bolts into the side of the gearbox is replacable? ie "the send unit"? which is mechanically drivin? guessing toyota has these? Report
December 28, 201015 yr comment_491029 What gearbox/diff ratio do you have, that will determine what part you need. Report
December 28, 201015 yr Author comment_491040 What gearbox/diff ratio do you have, that will determine what part you need. it is a T50 and a stock ae71/ke70 diff, i am unsure of what ratios it is and way to find out? Report
