Yes it is. Prepare for either no other replies or alot of abuse. A few people on this site has done this conversion so check out the search function and you'll find heaps of topics on this.
  • Upvote 1
All 4A blocks have the same basic mounting provisions. You can cut and shut or get a factory JDM bigport intake from an AE86. AE71 or AE86 have all the mechanical bits you need, mounts, rwd gearbox etc etc, clutch spline matches too, just bolts up, as does the 4ac rwd starter.
You can rearrange the mounts on the xmember to suit the 4A factory rwd mounts or make or possibly buy custom mounts techo toy tuning; starlet 4A onto K crossmember may be worth a look, just need to use www.toyodiy.com to make sure the mounts on your car and the starlet are a match, both K powered and similar width, I'd do some research.
The TRDKE70 boys would know if the mounts are the same heaps more RWD starlets in NZ
Edited by beerhead
